Aller au contenu principal
HP EliteBook x360 830 G5 M2 Solid State Drive Replacement
Ce dont vous avez besoin
  1. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, Back Cover: étape 1, image 1 de 1
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: étape 2, image 1 de 2 HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: étape 2, image 2 de 2
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: étape 3, image 1 de 1
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, M.2 Solid State Drive: étape 4, image 1 de 1
    • Pull the tab attached to the M.2 solid state drive shield up.
  5. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: étape 5, image 1 de 1
    • With the Phillips #1 screwdriver, loosen the single screw that secures the M.2 solid state drive to the system board.
  6. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: étape 6, image 1 de 1
    • Once the springs release, carefully remove the M.2 solid state drive.
    • Pull the SSD card gently so you don't bend any pins.
Ashia Lewis
Membre depuis le 09/03/21
246 Réputation
2 tutoriels rédigés
Équipe
University of Alabama, Team 1-4, Bedsole Fall 2021 Membre de l'équipe University of Alabama, Team 1-4, Bedsole Fall 2021
UA-BEDSOLE-F21S1G4
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 22
Total : 551
