Aller au contenu principal
HP EliteBook x360 830 G7 Display Replacement
Ce dont vous avez besoin
  1. HP EliteBook x360 830 G7 Display Replacement, Remove the display: étape 1, image 1 de 3 HP EliteBook x360 830 G7 Display Replacement, Remove the display: étape 1, image 2 de 3 HP EliteBook x360 830 G7 Display Replacement, Remove the display: étape 1, image 3 de 3
    • Use an opening tool to remove the display from the laptop case. Place it in the area that you see the most give.
    • If you hear the plastic tabs "snapping" free, you should be fine.
    • Be careful not to crack the display.
  2. HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: étape 2, image 1 de 3 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: étape 2, image 2 de 3 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: étape 2, image 3 de 3
    • With the screen removed, locate the pair of wires hidden underneath the two pieces of tape.
  3. HP EliteBook x360 830 G7 Display Replacement, Connector bracket: étape 3, image 1 de 2 HP EliteBook x360 830 G7 Display Replacement, Connector bracket: étape 3, image 2 de 2
    • Use a plastic opening tool or nylon spudger to lift the metal digitizer-connector bracket.
  4. HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: étape 4, image 1 de 3 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: étape 4, image 2 de 3 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: étape 4, image 3 de 3
    • Now that the bracket is removed, pull the golden connector away from the silver base.
    • Now, the back of the display should look like this.
  5. HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: étape 5, image 1 de 3 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: étape 5, image 2 de 3 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: étape 5, image 3 de 3
    • The next piece of tape that needs to be peeled, but not removed, is highlighted by the red rectangle.
    • Peel but do not remove the black piece of tape.
  6. HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: étape 6, image 1 de 3 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: étape 6, image 2 de 3 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: étape 6, image 3 de 3
    • Peel, but do not remove entirely, the clear piece of tape that was underneath the black tape.
  7. HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: étape 7, image 1 de 3 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: étape 7, image 2 de 3 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: étape 7, image 3 de 3
    • Pull the small, bronze "Brighton" ribbon cable connector from the tan connection base.
  8. HP EliteBook x360 830 G7 Display Replacement, Separate the display housing from the computer: étape 8, image 1 de 1
    • If you can move your display's housing away from the computer, then you have successfully detached your display and can replace it.
Jonathan Bond
Membre depuis le 03/21/22
207 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 66
Total : 1,356
