Aller au contenu principal
HP EliteBook x360 830 G7 RAM Replacement
Ce dont vous avez besoin
  1. HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: étape 1, image 1 de 2 HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: étape 1, image 2 de 2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: étape 2, image 1 de 3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: étape 2, image 2 de 3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: étape 2, image 3 de 3
    • Gently lift the larger, rectangular metal shielding off. This shielding covers the RAM.
  3. HP EliteBook x360 830 G7 RAM Replacement, Remove the RAM: étape 3, image 1 de 1
    • Push down on the two latches on both sides of the RAM to release it.
    • This will allow you to remove the RAM and replace it with no issues.
Abigail Herring
Membre depuis le 03/21/22
165 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 72
Total : 1,068
