Aller au contenu principal
HP EliteOne 800 G1 Power Supply Replacement
Ce dont vous avez besoin
  1. HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: étape 1, image 1 de 3 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: étape 1, image 2 de 3 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: étape 1, image 3 de 3
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: étape 2, image 1 de 2 HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: étape 2, image 2 de 2
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
  3. HP EliteOne 800 G1 Power Supply Replacement: étape 3, image 1 de 2 HP EliteOne 800 G1 Power Supply Replacement: étape 3, image 2 de 2
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
  4. HP EliteOne 800 G1 Power Supply Replacement: étape 4, image 1 de 2 HP EliteOne 800 G1 Power Supply Replacement: étape 4, image 2 de 2
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
  5. HP EliteOne 800 G1 Power Supply Replacement, Power Supply: étape 5, image 1 de 2 HP EliteOne 800 G1 Power Supply Replacement, Power Supply: étape 5, image 2 de 2
    • Use a Torx T15 driver to remove the four 10mm screws on the VESA mount cover.
    • Lift up on the VESA mount cover to remove it.
  6. HP EliteOne 800 G1 Power Supply Replacement: étape 6, image 1 de 1
    • Disconnect the power supply's black and yellow cable from the motherboard.
  7. HP EliteOne 800 G1 Power Supply Replacement: étape 7, image 1 de 2 HP EliteOne 800 G1 Power Supply Replacement: étape 7, image 2 de 2
    • Use a Torx T15 driver to remove the two 8mm screws on either side of the power supply.
    • Lift the power supply from the case to remove it.
6 autres ont terminé cette réparation.
Michael Ewing
Membre depuis le 10/01/15
1 071 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 1-24, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 27
Total : 5,377
