Aller au contenu principal
HP Elitebook 820 G1 Keyboard Replacement
Ce dont vous avez besoin
  1. HP Elitebook 820 G1 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Keyboard Replacement: étape 2, image 1 de 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Keyboard Replacement: étape 3, image 1 de 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Keyboard Replacement: étape 4, image 1 de 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Keyboard Replacement, Keyboard: étape 5, image 1 de 1
    • Remove the two Phillips #0 screws securing the keyboard to the laptop.
    • Turn the laptop over and lift the display to reveal the keyboard.
  6. HP Elitebook 820 G1 Keyboard Replacement: étape 6, image 1 de 1
    • Insert the plastic spudger between the keyboard and the housing.
    • Start at the corner.
  7. HP Elitebook 820 G1 Keyboard Replacement: étape 7, image 1 de 3 HP Elitebook 820 G1 Keyboard Replacement: étape 7, image 2 de 3 HP Elitebook 820 G1 Keyboard Replacement: étape 7, image 3 de 3
    • 4 tabs are located at the top of the keyboard, which lock it in place.
    • Pry and twist the spudger along the top of the keyboard until each tab is released.
  8. HP Elitebook 820 G1 Keyboard Replacement: étape 8, image 1 de 1
    • Pull back the keyboard from the top.
    • Be mindful of the fragile cables behind it.
  9. HP Elitebook 820 G1 Keyboard Replacement: étape 9, image 1 de 3 HP Elitebook 820 G1 Keyboard Replacement: étape 9, image 2 de 3 HP Elitebook 820 G1 Keyboard Replacement: étape 9, image 3 de 3
    • Flip up the connecting flap on each of the three ribbon cables.
    • The small cable on the last picture ist only there, if you have a backlit keyboard. If you want to replace a keyboard without backlight, there will be no cable on your original keyboard.
  10. HP Elitebook 820 G1 Keyboard Replacement: étape 10, image 1 de 3 HP Elitebook 820 G1 Keyboard Replacement: étape 10, image 2 de 3 HP Elitebook 820 G1 Keyboard Replacement: étape 10, image 3 de 3
    • Remove each of the three cables by gently pulling them from their respective connectors.
  11. HP Elitebook 820 G1 Keyboard Replacement: étape 11, image 1 de 1
    • Remove the keyboard from the housing.
4 autres ont terminé cette réparation.
Lauren Vance
Membre depuis le 10/31/18
388 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G2, Harley Fall 2018 Membre de l'équipe IUPUI, Team S1-G2, Harley Fall 2018
IUPUI-HARLEY-F18S1G2
2 membres
4 tutoriels rédigés
Un commentaire
Good guide. Thanks!
But you missed step 1. Remove two screws that hold the keyboard in place
Chris Maschmeier - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 56
Total : 11,081
