Aller au contenu principal
HP Elitebook 820 G1 Monitor Display Replacement
Ce dont vous avez besoin
  1. HP Elitebook 820 G1 Monitor Display Replacement, Battery: étape 1, image 1 de 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Monitor Display Replacement: étape 2, image 1 de 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Monitor Display Replacement: étape 3, image 1 de 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Monitor Display Replacement: étape 4, image 1 de 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Monitor Display Replacement, Fan: étape 5, image 1 de 1
    • Remove the hard drive by unscrewing the four 8mm screws with the T7 philip's head.
  6. HP Elitebook 820 G1 Monitor Display Replacement: étape 6, image 1 de 1
    • Pry off ten rubber paddings on the outer edge of the laptop to reveal the torx screws.
    • Unscrew the ten 8mm torx screws that are under the rubber paddings using the T7 tip torx screwdriver.
  7. HP Elitebook 820 G1 Monitor Display Replacement: étape 7, image 1 de 1
    • Remove the two 4mm screws indicated by the M2.5X4 using the J00 tip screwdriver.
    • Remove SD card cap by just sliding out to reveal one screw.
  8. HP Elitebook 820 G1 Monitor Display Replacement: étape 8, image 1 de 1
    • Remove the two 3mm screws indicated by the M2.03 using the J00 tip screwdriver.
    • Remove the 4mm SD card screw using the J00 tip.
  9. HP Elitebook 820 G1 Monitor Display Replacement: étape 9, image 1 de 1
    • Remove the one 4mm fan screw using the J00 tip screwdriver.
    • Remove screw and metal plate to expose ribbon cable connector.
  10. HP Elitebook 820 G1 Monitor Display Replacement: étape 10, image 1 de 1
    • Use an opening tool to pry up the ribbon connector to disconnect.
  11. HP Elitebook 820 G1 Monitor Display Replacement: étape 11, image 1 de 1
    • Turn laptop over back to normal position as shown in the image.
    • Use opening tools to pry up keyboard.
    • When prying up keyboard, be sure to start near any corner of the keyboard.
    • There are two ribbon cables that must be disconnected before fully removing keyboard.
  12. HP Elitebook 820 G1 Monitor Display Replacement: étape 12, image 1 de 3 HP Elitebook 820 G1 Monitor Display Replacement: étape 12, image 2 de 3 HP Elitebook 820 G1 Monitor Display Replacement: étape 12, image 3 de 3
    • Carefully lift keyboard on one side to expose the two ribbon cables.
    • Use an opening tool to lift up the locking clip and unplug the two ribbon cables.
  13. HP Elitebook 820 G1 Monitor Display Replacement: étape 13, image 1 de 1
    • Remove the two 4mm screws centered notated by the keyboard logo using the J00 tip.
  14. HP Elitebook 820 G1 Monitor Display Replacement: étape 14, image 1 de 3 HP Elitebook 820 G1 Monitor Display Replacement: étape 14, image 2 de 3 HP Elitebook 820 G1 Monitor Display Replacement: étape 14, image 3 de 3
    • Once keyboard has been fully removed, the system case containing the motherboard can be lifted out easily.
    • The display is connected to the shell of the laptop.
  15. HP Elitebook 820 G1 Monitor Display Replacement: étape 15, image 1 de 1
    • Unplug fan cable by pulling away from its connector.
  16. HP Elitebook 820 G1 Monitor Display Replacement: étape 16, image 1 de 1
    • Unscrew the two 6mm fan screws using the J00 tip.
    • Fan screws are encased in springs and cannot be removed.
  17. HP Elitebook 820 G1 Monitor Display Replacement, Monitor display: étape 17, image 1 de 1
    • Retrieve the monitor display connected to the plastic chassis.
  18. HP Elitebook 820 G1 Monitor Display Replacement: étape 18, image 1 de 1
    • Unscrew the two 4mm hinge screws using the Philips 00 tip screwdriver.
  19. HP Elitebook 820 G1 Monitor Display Replacement: étape 19, image 1 de 1
    • Unhinge the monitor display from the chassis.
Alberto Carlos Perez
Membre depuis le 02/14/18
365 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S5-G1, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 membres
7 tutoriels rédigés
Un commentaire
Hello,
I need to replace the inverter as my screen is too much dark.
I cannot see the inverter and even I cannot find any inverter for this model.
Do you know how to access to this inverter? Is it embedded within the screen?
Thanks by advance.
BR
richard P - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 29
Total : 3,260
