Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Elitebook 840 G1 RAM Replacement
Ce dont vous avez besoin
  1. HP Elitebook 840 G1 RAM Replacement, Battery: étape 1, image 1 de 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Slide the latch, to the right, away from the lock symbol.
    • Slide the cover away from the latch to remove it.
    Demander à FixBot
    Ajouter un commentaire
  2. HP Elitebook 840 G1 RAM Replacement: étape 2, image 1 de 1
    • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
    Demander à FixBot
  3. HP Elitebook 840 G1 RAM Replacement: étape 3, image 1 de 1
    • Battery should easily be lifted up and out.
    Demander à FixBot
  4. HP Elitebook 840 G1 RAM Replacement, RAM: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    • Identify the RAM and the pull tabs that will be used in the next step.
    • Always use an anti-static wrist strap when working on a computer.
    Demander à FixBot
  5. HP Elitebook 840 G1 RAM Replacement: étape 5, image 1 de 1
    • Pull back the two tabs on either side of the RAM this will allow the RAM to be removed.
    • When handling a memory module, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
    Demander à FixBot
  6. HP Elitebook 840 G1 RAM Replacement: étape 6, image 1 de 1
    • Pull the RAM stick gently out and up once the tabs have been pulled to the side.
    Demander à FixBot
8 autres ont terminé cette réparation.
Ashley Williams
Membre depuis le 08/27/15
2 455 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 5-3, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 5-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G3
4 membres
19 tutoriels rédigés
1 commentaire de tutoriel
Bonjour,
Ce tuto est clair, merci ! :)
christophe.ducard - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 60
Total : 10,042
