Aller au contenu principal
HP Elitebook 8460p Cooling Fan Replacement
Ce dont vous avez besoin
  1. HP Elitebook 8460p Cooling Fan Replacement, Battery: étape 1, image 1 de 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Cooling Fan Replacement: étape 2, image 1 de 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Cooling Fan Replacement, Back Panel: étape 3, image 1 de 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Cooling Fan Replacement: étape 4, image 1 de 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: étape 5, image 1 de 2 HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: étape 5, image 2 de 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
  6. HP Elitebook 8460p Cooling Fan Replacement: étape 6, image 1 de 2 HP Elitebook 8460p Cooling Fan Replacement: étape 6, image 2 de 2
    • Pull the fan straight up and to the side slightly.
  7. HP Elitebook 8460p Cooling Fan Replacement: étape 7, image 1 de 2 HP Elitebook 8460p Cooling Fan Replacement: étape 7, image 2 de 2
    • Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
  8. HP Elitebook 8460p Cooling Fan Replacement: étape 8, image 1 de 1
    • Using a Phillips #0 bit, unscrew the six screws on the heat sink.
  9. HP Elitebook 8460p Cooling Fan Replacement: étape 9, image 1 de 2 HP Elitebook 8460p Cooling Fan Replacement: étape 9, image 2 de 2
    • Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
    • Clean and replace the thermal paste on the processor if you have any thermal paste.
  10. HP Elitebook 8460p Cooling Fan Replacement: étape 10, image 1 de 1
    • Blow compressed air through the vent from the outside and through the heat sink.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 15
30 derniers jours : 49
Total : 4,486
