Aller au contenu principal
HP Elitebook 8570w Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Elitebook 8570w Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • To begin, you will need to remove the battery by sliding the left slider (red) to the left.
    • Push the battery away from you to release it.
    • Then, use the right slider to remove the computer's backing (shown in image)
    • Slide the backing towards you to remove it.
  2. HP Elitebook 8570w Hard Drive Replacement: étape 2, image 1 de 1
    • Once the backing has been removed, you will be able to locate the computer's hard drive in the bottom left corner.
  3. HP Elitebook 8570w Hard Drive Replacement: étape 3, image 1 de 1
    • To remove the hard drive compartment's cover, unscrew the two 0.8mm Phillips screws with a P1 Phillips-head screwdriver.
    • Open by lifting the left side of the cover so it is facing upwards and outwards.
    • The black screws, not the gold screws.
  4. HP Elitebook 8570w Hard Drive Replacement: étape 4, image 1 de 1
    • Use the same screwdriver to loosen all three screws at the attachment points of the silver hard drive caddy.
    • These screws do not need to be completely removed.
  5. HP Elitebook 8570w Hard Drive Replacement: étape 5, image 1 de 1
    • To remove the caddy and gain access to the hard drive, pull the black tab up to release it from the caddy.
    • Once you can grab the tab with your fingers, pull it to the left to disconnect the hard drive from the computer.
  6. HP Elitebook 8570w Hard Drive Replacement: étape 6, image 1 de 1
    • The hard drive can now be replaced inside the caddy.
5 autres ont terminé cette réparation.
MJ Routh
Membre depuis le 11/06/17
465 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S8-G5, Johnson Fall 2017 Membre de l'équipe Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 53
Total : 14,425
