Introduction
This guide provides instructions to help you replace your SSD in case there is an issue and you want to upgrade or replace it. The SSD is a solid state drive that stores accessible memory on your device.
Ce dont vous avez besoin
Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
Use the Phillips 0 screwdriver to remove the 2mm Phillips screws from the SSD assembly.
Gently slide the SSD to the right and pull out to remove it from its position within the motherboard.
3 autres ont terminé cette réparation.
