Aller au contenu principal
HP Elitebook x360 1040 G5 Touchpad Replacement
Ce dont vous avez besoin
  1. HP Elitebook x360 1040 G5 Touchpad Replacement, Lower Case: étape 1, image 1 de 2 HP Elitebook x360 1040 G5 Touchpad Replacement, Lower Case: étape 1, image 2 de 2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Touchpad Replacement: étape 2, image 1 de 2 HP Elitebook x360 1040 G5 Touchpad Replacement: étape 2, image 2 de 2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Touchpad Replacement, Battery: étape 3, image 1 de 2 HP Elitebook x360 1040 G5 Touchpad Replacement, Battery: étape 3, image 2 de 2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Touchpad Replacement: étape 4, image 1 de 3 HP Elitebook x360 1040 G5 Touchpad Replacement: étape 4, image 2 de 3 HP Elitebook x360 1040 G5 Touchpad Replacement: étape 4, image 3 de 3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
  5. HP Elitebook x360 1040 G5 Touchpad Replacement, Touchpad: étape 5, image 1 de 2 HP Elitebook x360 1040 G5 Touchpad Replacement, Touchpad: étape 5, image 2 de 2
    • Use the Phillips 0 screwdriver to remove the six 3mm Phillips screws from the touchpad assembly.
  6. HP Elitebook x360 1040 G5 Touchpad Replacement: étape 6, image 1 de 3 HP Elitebook x360 1040 G5 Touchpad Replacement: étape 6, image 2 de 3 HP Elitebook x360 1040 G5 Touchpad Replacement: étape 6, image 3 de 3
    • Gently pull on the blue tab to remove the ribbon connecting the touchpad to the motherboard on the left hand side.
    • Gently pull on the blue tab to remove the ribbon connecting the touchpad to the motherboard on the right hand side.
  7. HP Elitebook x360 1040 G5 Touchpad Replacement: étape 7, image 1 de 1
    • Gently pull up on the top two corners of the touchpad and remove it from the laptop.
Corey Agena
Membre depuis le 04/21/19
833 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S1-G4, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S1-G4, Maness Spring 2019
CPSU-MANESS-S19S1G4
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 19
Total : 688
