Aller au contenu principal
HP Envy 15-u001dx Chassis Replacement
Ce dont vous avez besoin
  1. HP Envy 15-u001dx Chassis Replacement, Motherboard: étape 1, image 1 de 3 HP Envy 15-u001dx Chassis Replacement, Motherboard: étape 1, image 2 de 3 HP Envy 15-u001dx Chassis Replacement, Motherboard: étape 1, image 3 de 3
    • Flip the device over so the bottom is is facing up.
    • Peel up the two rubber feet closest to the hinge using the metal spudger to reveal two 6.6 mm Phillips #0 screws.
  2. HP Envy 15-u001dx Chassis Replacement: étape 2, image 1 de 2 HP Envy 15-u001dx Chassis Replacement: étape 2, image 2 de 2
    • Peel up the small plastic coverings in the middle of the device with the spudger to reveal two more 6.6 mm Phillips #0 screws.
  3. HP Envy 15-u001dx Chassis Replacement: étape 3, image 1 de 2 HP Envy 15-u001dx Chassis Replacement: étape 3, image 2 de 2
    • Remove each of the fourteen 6.6 mm Phillips #0 screws with the Philips #0 screwdriver.
  4. HP Envy 15-u001dx Chassis Replacement: étape 4, image 1 de 1
    • Flip the device over and open it to reveal the keyboard.
    • Use the metal spudger to pry the chassis apart and reveal the inside of the device.
  5. HP Envy 15-u001dx Chassis Replacement: étape 5, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 5, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 5, image 3 de 3
    • Disconnect the T/P cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  6. HP Envy 15-u001dx Chassis Replacement: étape 6, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 6, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 6, image 3 de 3
    • Disconnect the keyboard cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  7. HP Envy 15-u001dx Chassis Replacement: étape 7, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 7, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 7, image 3 de 3
    • Disconnect the battery cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  8. HP Envy 15-u001dx Chassis Replacement: étape 8, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 8, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 8, image 3 de 3
    • Disconnect the AUX/USB cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  9. HP Envy 15-u001dx Chassis Replacement: étape 9, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 9, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 9, image 3 de 3
    • Disconnect the cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  10. HP Envy 15-u001dx Chassis Replacement: étape 10, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 10, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 10, image 3 de 3
  11. HP Envy 15-u001dx Chassis Replacement: étape 11, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 11, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 11, image 3 de 3
  12. HP Envy 15-u001dx Chassis Replacement: étape 12, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 12, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 12, image 3 de 3
    • Disconnect the cable by gently pulling it out. The spudger may be used to help loosen it.
  13. HP Envy 15-u001dx Chassis Replacement: étape 13, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 13, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 13, image 3 de 3
    • Remove the three 4.0 mm Phillips #0 screws with the Phillips #0 screwdriver on the fan.
    • Remove the fan by pulling it out of the chassis.
    • The connector tends to get stuck and forceful pulling will break it. Use the spudger to loosen the connector on each side.
  14. HP Envy 15-u001dx Chassis Replacement: étape 14, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 14, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 14, image 3 de 3
    • This connector may be hard to see because it is connected on the underside of the motherboard.
  15. HP Envy 15-u001dx Chassis Replacement: étape 15, image 1 de 1
    • Remove each of the six 4.0 mm screws with the Philips #0 screwdriver.
  16. HP Envy 15-u001dx Chassis Replacement: étape 16, image 1 de 1
    • Remove each of the three 4.0 mm screws around the fan with the Philips #0 screwdriver.
    • The fan will now be loose, and easy to lift out.
  17. HP Envy 15-u001dx Chassis Replacement: étape 17, image 1 de 2 HP Envy 15-u001dx Chassis Replacement: étape 17, image 2 de 2
    • Gently pry the heat sink loose to release the motherboard.
  18. HP Envy 15-u001dx Chassis Replacement: étape 18, image 1 de 2 HP Envy 15-u001dx Chassis Replacement: étape 18, image 2 de 2
    • Disconnect the wifi card from the motherboard and remove the motherboard from the rest of the device.
  19. HP Envy 15-u001dx Chassis Replacement: étape 19, image 1 de 1
    • The disconnected motherboard should look like the indicated photo.
  20. HP Envy 15-u001dx Chassis Replacement, Chassis: étape 20, image 1 de 3 HP Envy 15-u001dx Chassis Replacement, Chassis: étape 20, image 2 de 3 HP Envy 15-u001dx Chassis Replacement, Chassis: étape 20, image 3 de 3
    • Remove the three 4mm Phillips #0 screws that attach the battery to the chassis.
    • Once all three 4mm Phillips #0 screws are out, lift the battery out of the chassis.
  21. HP Envy 15-u001dx Chassis Replacement: étape 21, image 1 de 2 HP Envy 15-u001dx Chassis Replacement: étape 21, image 2 de 2
    • Carefully, use the spudger, to loosen the I/O port board connector.
    • Once the connector is loose, simply pull it away.
  22. HP Envy 15-u001dx Chassis Replacement: étape 22, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 22, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 22, image 3 de 3
    • Remove the 4mm Phillips #0 screw that attaches the left speaker to the chassis.
    • Lift the left side speaker out of the chassis.
    • Remove the 4mm Phillips #0 screw that attaches the right speaker to the chassis.
  23. HP Envy 15-u001dx Chassis Replacement: étape 23, image 1 de 3 HP Envy 15-u001dx Chassis Replacement: étape 23, image 2 de 3 HP Envy 15-u001dx Chassis Replacement: étape 23, image 3 de 3
    • Remove the 4mm Phillips #0 screw attaching the volume circuitry board to the chassis.
    • Once screw has been removed, then simply pull the circuitry board out.
  24. HP Envy 15-u001dx Chassis Replacement: étape 24, image 1 de 2 HP Envy 15-u001dx Chassis Replacement: étape 24, image 2 de 2
    • Remove the 4 mm Phillips #0 screws attaching the power button circuitry board to the chassis.
    • Once all the screws are removed, then simply pull the circuitry board out.
  25. HP Envy 15-u001dx Chassis Replacement: étape 25, image 1 de 2 HP Envy 15-u001dx Chassis Replacement: étape 25, image 2 de 2
    • Remove the two 4mm Phillips #0 screws that attach the storage device to the chassis.
    • Then pull up on the storage device to get it pop it out of the chassis.
  26. HP Envy 15-u001dx Chassis Replacement: étape 26, image 1 de 1
    • Remove the 6.6mm Phillips #0 screws that attach the screen to the right side of the chassis.
  27. HP Envy 15-u001dx Chassis Replacement: étape 27, image 1 de 2 HP Envy 15-u001dx Chassis Replacement: étape 27, image 2 de 2
    • Remove the two 6.6mm Phillips #0 screws that attach the hinge to the chassis on the left side.
  28. HP Envy 15-u001dx Chassis Replacement: étape 28, image 1 de 2 HP Envy 15-u001dx Chassis Replacement: étape 28, image 2 de 2
    • After you remove the screen, all that is left is the chassis!
Samuel Olubakinde
Membre depuis le 11/04/19
169 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G1, Henning Fall 2019 Membre de l'équipe IUPUI, Team S1-G1, Henning Fall 2019
IUPUI-HENNING-F19S1G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 18
Total : 1,082
