Aller au contenu principal
HP Envy 15-u001dx Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Envy 15-u001dx Hard Drive Replacement, HP Envy 15-u001dx Disassembly: étape 1, image 1 de 1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Hard Drive Replacement: étape 2, image 1 de 1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Hard Drive Replacement: étape 3, image 1 de 1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Hard Drive Replacement: étape 4, image 1 de 1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Hard Drive Replacement: étape 5, image 1 de 2 HP Envy 15-u001dx Hard Drive Replacement: étape 5, image 2 de 2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Hard Drive Replacement, Hard Drive: étape 6, image 1 de 1
    • Gently remove hard drive from its connector.
2 autres ont terminé cette réparation.
Dakota Presley
Membre depuis le 10/05/16
885 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 9-4, Lacy Fall 2016 Membre de l'équipe USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 21
Total : 1,885
