Aller au contenu principal
HP Envy 17-3070NR Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: étape 1, image 1 de 2 HP Envy 17-3070NR Optical Drive Replacement, Back Cover: étape 1, image 2 de 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Optical Drive Replacement: étape 2, image 1 de 3 HP Envy 17-3070NR Optical Drive Replacement: étape 2, image 2 de 3 HP Envy 17-3070NR Optical Drive Replacement: étape 2, image 3 de 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: étape 3, image 1 de 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: étape 3, image 2 de 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: étape 3, image 3 de 3
    • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
    • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
    • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
    • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
  4. HP Envy 17-3070NR Optical Drive Replacement: étape 5, image 1 de 3 HP Envy 17-3070NR Optical Drive Replacement: étape 5, image 2 de 3 HP Envy 17-3070NR Optical Drive Replacement: étape 5, image 3 de 3
    • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
Jon Fuson
Membre depuis le 04/21/15
140 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 14-8, Amido Spring 2015 Membre de l'équipe Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 8
Total : 1,222
