Aller au contenu principal
HP Envy 17-3070NR RAM Replacement
Ce dont vous avez besoin
  1. HP Envy 17-3070NR RAM Replacement, Back Cover: étape 1, image 1 de 2 HP Envy 17-3070NR RAM Replacement, Back Cover: étape 1, image 2 de 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR RAM Replacement: étape 2, image 1 de 3 HP Envy 17-3070NR RAM Replacement: étape 2, image 2 de 3 HP Envy 17-3070NR RAM Replacement: étape 2, image 3 de 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR RAM Replacement, RAM: étape 3, image 1 de 3 HP Envy 17-3070NR RAM Replacement, RAM: étape 3, image 2 de 3 HP Envy 17-3070NR RAM Replacement, RAM: étape 3, image 3 de 3
    • Press down on both tabs on either side of the top RAM stick.
    • The RAM will slightly pop out and you will be able to slide it out of it's cavity.
    • Repeat the same process for the second stick of RAM if needed.
Abby Lentz
Membre depuis le 04/21/15
586 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 14-8, Amido Spring 2015 Membre de l'équipe Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 755
