Aller au contenu principal
HP Envy 17-J013CL Memory Module Replacement
Ce dont vous avez besoin
  1. HP Envy 17-J013CL Memory Module Replacement, Battery: étape 1, image 1 de 1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Memory Module Replacement: étape 2, image 1 de 1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Memory Module Replacement: étape 3, image 1 de 3 HP Envy 17-J013CL Memory Module Replacement: étape 3, image 2 de 3 HP Envy 17-J013CL Memory Module Replacement: étape 3, image 3 de 3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Memory Module Replacement, Back Panel: étape 4, image 1 de 2 HP Envy 17-J013CL Memory Module Replacement, Back Panel: étape 4, image 2 de 2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Memory Module Replacement: étape 5, image 1 de 1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL Memory Module Replacement, Memory Module: étape 6, image 1 de 2 HP Envy 17-J013CL Memory Module Replacement, Memory Module: étape 6, image 2 de 2
    • Locate the memory stick inside.
  7. HP Envy 17-J013CL Memory Module Replacement: étape 7, image 1 de 2 HP Envy 17-J013CL Memory Module Replacement: étape 7, image 2 de 2
    • On both sides of the module, place a thumb on each of the metallic holding pins.
    • Gently pull on the pins to release the spring holding in the module.
  8. HP Envy 17-J013CL Memory Module Replacement: étape 8, image 1 de 2 HP Envy 17-J013CL Memory Module Replacement: étape 8, image 2 de 2
    • Gently slide the module out of the memory slot.
    • Pay in mind of the module's orientation as it will only go in one way with a little gap in the module to identify orientation.
Matt McBride
Membre depuis le 02/02/17
845 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 16-6, Blackwell Spring 2017 Membre de l'équipe USF Tampa, Team 16-6, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 658
