Introduction
Is your HP Envy 17m-ae111dx getting really hot? If so, here is the guide to fix the problem with a replacement of the CPU fan. You will need is the iFixit Opening Tool, a 00 Phillips-head Screwdriver, and a T5 Torx-Head Screwdriver.
Ce dont vous avez besoin
Unscrew all visible screws.
Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
Use the Phillips #00 screwdriver to remove the three 5.5mm screws that secure the fan.
Unplug the wire that is connected to the fan and move the wires so they are out of the way of the fan.
Remove the tape off of the fan that is holding the wires in place against the fan.
3 autres ont terminé cette réparation.
