Aller au contenu principal
HP Envy 23-d060qd TouchSmart Speaker Replacement
Ce dont vous avez besoin
  1. HP Envy 23-d060qd TouchSmart Speaker Replacement, Back Panel: étape 1, image 1 de 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Speaker Replacement: étape 2, image 1 de 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Speaker Replacement: étape 3, image 1 de 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Speaker Replacement, Speakers: étape 4, image 1 de 1
    • Remove the receiver for the keyboard and mouse with your hands.
  5. HP Envy 23-d060qd TouchSmart Speaker Replacement: étape 5, image 1 de 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: étape 5, image 2 de 2
    • Remove the four 17.5mm T15 screws from the speakers.
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate with your hands.
  6. HP Envy 23-d060qd TouchSmart Speaker Replacement: étape 6, image 1 de 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: étape 6, image 2 de 2
    • Disconnect the two speaker connections from the motherboard with your hands. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when disconnecting any wired connections. Pulling on the wires can damage them.
  7. HP Envy 23-d060qd TouchSmart Speaker Replacement: étape 7, image 1 de 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: étape 7, image 2 de 2
    • Remove the speakers from the computer, and if needed, separate by disconnecting the wires between them.
    • Be gentle when separating wired connections. Pulling on the wires can damage them.
Zachary Dicks
Membre depuis le 10/01/15
1 135 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-10, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 membres
14 tutoriels rédigés
Un commentaire
where to get the replacement speaker???????
Clovis Young - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 36
Total : 1,566
