Aller au contenu principal
HP Envy 4-1030us Battery Replacement
Ce dont vous avez besoin
  1. HP Envy 4-1030us Battery Replacement, Bottom Cover: étape 1, image 1 de 2 HP Envy 4-1030us Battery Replacement, Bottom Cover: étape 1, image 2 de 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Battery Replacement: étape 2, image 1 de 2 HP Envy 4-1030us Battery Replacement: étape 2, image 2 de 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Battery Replacement, Battery: étape 3, image 1 de 2 HP Envy 4-1030us Battery Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery cable from the motherboard. This will be found above the battery and below the CPU fan.
    • To take the cable out, carefully grab the head of the cable and slowly pull it outwards.
  4. HP Envy 4-1030us Battery Replacement: étape 4, image 1 de 2 HP Envy 4-1030us Battery Replacement: étape 4, image 2 de 2
    • Use the Philips #0 screwdriver to remove the three 4.2mm screws that are securing the battery to the board.
  5. HP Envy 4-1030us Battery Replacement: étape 5, image 1 de 2 HP Envy 4-1030us Battery Replacement: étape 5, image 2 de 2
    • Then slowly remove the battery from the right side of the battery and then raise it up.
    • Make sure to move the USB Audio board cable away from the battery incase it gets caught.
2 autres ont terminé cette réparation.
Christopher Luna
Membre depuis le 10/08/17
700 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 6
Total : 945
