Aller au contenu principal
HP Envy 4-1030us CPU Fan Replacement
Ce dont vous avez besoin
  1. HP Envy 4-1030us CPU Fan Replacement, Bottom Cover: étape 1, image 1 de 2 HP Envy 4-1030us CPU Fan Replacement, Bottom Cover: étape 1, image 2 de 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us CPU Fan Replacement: étape 2, image 1 de 2 HP Envy 4-1030us CPU Fan Replacement: étape 2, image 2 de 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us CPU Fan Replacement, CPU Fan: étape 3, image 1 de 1
    • Using the Phillips #0 screwdriver unscrew the two 4.2mm screws fastening the CPU fan to the heatsink and motherboard.
  4. HP Envy 4-1030us CPU Fan Replacement: étape 4, image 1 de 2 HP Envy 4-1030us CPU Fan Replacement: étape 4, image 2 de 2
    • Carefully lift up the CPU fan to gain better access to the fan cable.
    • Disconnect the fan cable by pulling the cable away from the connector and remove the fan from the device.
Christopher Luna
Membre depuis le 10/08/17
700 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 381
