Aller au contenu principal
HP Envy 4-1030us Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Envy 4-1030us Hard Drive Replacement, Bottom Cover: étape 1, image 1 de 2 HP Envy 4-1030us Hard Drive Replacement, Bottom Cover: étape 1, image 2 de 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Hard Drive Replacement: étape 2, image 1 de 2 HP Envy 4-1030us Hard Drive Replacement: étape 2, image 2 de 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • After removing the cover the mSATA SSD should be visible near the center of the device.
    • Remove the one Phillips 2.5mm screw holding the SSD in place. The drive should pop up after removing the screw.
  4. HP Envy 4-1030us Hard Drive Replacement: étape 4, image 1 de 1
    • To remove the SSD grab the edges and pull it from the slot.
    • Try not to touch any pins or connectors. Damaged pins could result in permanent damage to the system.
Christopher Luna
Membre depuis le 10/08/17
700 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Thompson Fall 2017 Membre de l'équipe USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 843
