Aller au contenu principal
HP Envy 4-1105dx Battery Replacement
Ce dont vous avez besoin
  1. HP Envy 4-1105dx Battery Replacement, Battery: étape 1, image 1 de 1
    • Power off the device before beginning disassembly. Disconnect all external devices.
    • Flip the device on its back.
  2. HP Envy 4-1105dx Battery Replacement: étape 2, image 1 de 1
    • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
  3. HP Envy 4-1105dx Battery Replacement: étape 3, image 1 de 1
    • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
  4. HP Envy 4-1105dx Battery Replacement: étape 4, image 1 de 1
    • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
  5. HP Envy 4-1105dx Battery Replacement: étape 5, image 1 de 1
    • Once the device is open, move the ribbon cable to the side.
  6. HP Envy 4-1105dx Battery Replacement: étape 6, image 1 de 1
    • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
  7. HP Envy 4-1105dx Battery Replacement: étape 7, image 1 de 1
    • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
  8. HP Envy 4-1105dx Battery Replacement: étape 8, image 1 de 1
    • Lift the battery up and remove.
    • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
Parvathy Nambidi
Membre depuis le 05/17/17
304 Réputation
2 tutoriels rédigés
Équipe
Un commentaire
Worked very well, many thanks
Tony Chan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,230
