Introduction
Use this guide to replace the broken display on your HP Envy 4-1105dx.
Ce dont vous avez besoin
Close the device and turn it right-side up. Locate the two screw covers on the left and right side base of the display panel.
Remove the screw covers, using the black plastic spudger.
Remove the two 3.0 mm Phillips-front screws on the left and right hinges that secure the display panel to the computer, using a Phillips #1 screwdriver.
Pry open the plastic bezel case of the device using the plastic spudger. If the plastic spudger doesn't work, carefully use the metal spudger.
Loosen the edges of the case from all four sides of the display panel.
Once the back case pops out, close the laptop exposing the back display.
