Aller au contenu principal
HP Envy 4-1105dx Display Replacement
Ce dont vous avez besoin
  1. HP Envy 4-1105dx Display Replacement, Battery: étape 1, image 1 de 1
    • Power off the device before beginning disassembly. Disconnect all external devices.
    • Flip the device on its back.
  2. HP Envy 4-1105dx Display Replacement: étape 2, image 1 de 1
    • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
  3. HP Envy 4-1105dx Display Replacement: étape 3, image 1 de 1
    • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
  4. HP Envy 4-1105dx Display Replacement: étape 4, image 1 de 1
    • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
  5. HP Envy 4-1105dx Display Replacement: étape 5, image 1 de 1
    • Once the device is open, move the ribbon cable to the side.
  6. HP Envy 4-1105dx Display Replacement: étape 6, image 1 de 1
    • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
  7. HP Envy 4-1105dx Display Replacement: étape 7, image 1 de 1
    • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
  8. HP Envy 4-1105dx Display Replacement: étape 8, image 1 de 1
    • Lift the battery up and remove.
    • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
  9. HP Envy 4-1105dx Display Replacement, Display: étape 9, image 1 de 3 HP Envy 4-1105dx Display Replacement, Display: étape 9, image 2 de 3 HP Envy 4-1105dx Display Replacement, Display: étape 9, image 3 de 3
    • Close the device and turn it right-side up. Locate the two screw covers on the left and right side base of the display panel.
    • Remove the screw covers, using the black plastic spudger.
    • Remove the two 3.0 mm Phillips-front screws on the left and right hinges that secure the display panel to the computer, using a Phillips #1 screwdriver.
  10. HP Envy 4-1105dx Display Replacement: étape 10, image 1 de 3 HP Envy 4-1105dx Display Replacement: étape 10, image 2 de 3 HP Envy 4-1105dx Display Replacement: étape 10, image 3 de 3
    • Pry open the plastic bezel case of the device using the plastic spudger. If the plastic spudger doesn't work, carefully use the metal spudger.
    • Loosen the edges of the case from all four sides of the display panel.
    • Be careful not to use hands while opening, as the edges of the back case are sharp.
    • Once the back case pops out, close the laptop exposing the back display.
  11. HP Envy 4-1105dx Display Replacement: étape 11, image 1 de 2 HP Envy 4-1105dx Display Replacement: étape 11, image 2 de 2
    • Remove the four 4.0 mm Phillips display panel screws using Phillips #1 screwdriver.
    • Remove the four 2.0 mm Phillips screws using Phillips #00 screwdriver.
  12. HP Envy 4-1105dx Display Replacement: étape 12, image 1 de 3 HP Envy 4-1105dx Display Replacement: étape 12, image 2 de 3 HP Envy 4-1105dx Display Replacement: étape 12, image 3 de 3
    • Remove the four 4.0 mm Phillips silver screws on the hinges using a Phillips #1 screw driver.
    • Remove the two 6.0 mm Phillips black hinge cover screws using a Phillips #0 screw driver.
    • Flip and remove the hinge covers using a plastic spudger.
    • While flipping, be careful not bend the screen brackets.
  13. HP Envy 4-1105dx Display Replacement: étape 13, image 1 de 2 HP Envy 4-1105dx Display Replacement: étape 13, image 2 de 2
    • Disconnect the ribbon cable on the bottom of the display panel using a plastic spudger.
    • Disconnect the adjacent golden LCD connector using a plastic spudger.
  14. HP Envy 4-1105dx Display Replacement: étape 14, image 1 de 1
    • Remove the golden tape adhering to the display panel using a plastic spudger.
  15. HP Envy 4-1105dx Display Replacement: étape 15, image 1 de 1
    • Remove the white color wifi antennas from the display panel using a plastic spudger.
  16. HP Envy 4-1105dx Display Replacement: étape 16, image 1 de 3 HP Envy 4-1105dx Display Replacement: étape 16, image 2 de 3 HP Envy 4-1105dx Display Replacement: étape 16, image 3 de 3
    • Separate the transparent plastic tape that covers the circuit board using hands.
    • Carefully flip the circuit board.
    • Remove the black tape adhering to the green circuit board that is connected to the display panel.
  17. HP Envy 4-1105dx Display Replacement: étape 17, image 1 de 2 HP Envy 4-1105dx Display Replacement: étape 17, image 2 de 2
    • Using a plastic prying tool, remove the display panel.
    • This is the disassembled screen.
Parvathy Nambidi
Membre depuis le 05/17/17
304 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 976
