Aller au contenu principal
HP Envy 700-030qe CD Drive Replacement
Ce dont vous avez besoin
  1. HP Envy 700-030qe CD Drive Replacement, CD Drive: étape 1, image 1 de 2 HP Envy 700-030qe CD Drive Replacement, CD Drive: étape 1, image 2 de 2
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe CD Drive Replacement: étape 2, image 1 de 2 HP Envy 700-030qe CD Drive Replacement: étape 2, image 2 de 2
    • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
  3. HP Envy 700-030qe CD Drive Replacement: étape 3, image 1 de 1
    • For the next step, remove the CD drive power cable.
  4. HP Envy 700-030qe CD Drive Replacement: étape 4, image 1 de 1
    • Reorient the device with the front pointing away from you.
    • Next, remove the SATA interface cable. It is directly next to the power cable on the CD drive.
  5. HP Envy 700-030qe CD Drive Replacement: étape 5, image 1 de 1
    • Now pull up and swing the mounting lever in. The lever closest to the front mounts the top drive slot, and the lever farther away mounts the bottom one.
  6. HP Envy 700-030qe CD Drive Replacement: étape 6, image 1 de 2 HP Envy 700-030qe CD Drive Replacement: étape 6, image 2 de 2
    • Now stand your desktop up and remove the 3 clips on the right side of the front panel.
    • Then pull the front panel off, pulling from the side that the clips are on.
  7. HP Envy 700-030qe CD Drive Replacement: étape 7, image 1 de 1
    • Now you can pull the CD drive straight out of the casing!
Yoav Rosenberg
Membre depuis le 10/01/15
321 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 5-9, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 21
Total : 1,106
