Aller au contenu principal
HP Envy 700-030qe CPU Fan Replacement
Ce dont vous avez besoin
  1. HP Envy 700-030qe CPU Fan Replacement, CPU Fan: étape 1, image 1 de 3 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: étape 1, image 2 de 3 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: étape 1, image 3 de 3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe CPU Fan Replacement: étape 2, image 1 de 2 HP Envy 700-030qe CPU Fan Replacement: étape 2, image 2 de 2
    • Next, remove the side panel by sliding it towards the back of the desktop and pulling up, as shown.
  3. HP Envy 700-030qe CPU Fan Replacement: étape 3, image 1 de 1
    • Remove the four 120mm Phillips #000 head, 5 mm screws holding the fan.
  4. HP Envy 700-030qe CPU Fan Replacement: étape 4, image 1 de 1
    • Carefully pull up and disconnect the fan's power cable.
  5. HP Envy 700-030qe CPU Fan Replacement: étape 5, image 1 de 1
    • Remove the fan by pulling up carefully.
2 autres ont terminé cette réparation.
Jessica Resta
Membre depuis le 10/01/15
235 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 5-9, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 membres
10 tutoriels rédigés
4 commentaires
Im looking to replace the fan in mine, what size would I look for, or even what model would be best?
AzyP Zero - Réponse
Did you ever determine what fan to use ? I need to order one for my system.
Dennis - Réponse
I bought the Philips #000 Screwdriver from iFixit as listed above. It is not even close to what is needed. That screwdriver is like a jewelers tiny Philips head. It needs a much bigger screwdriver.
Dennis - Réponse
Fails to mention the most important part of the entire procedure. That would be to remove the old thermal paste from the top of the CPU with 91-99% isopropyl alcohol and re-apply new thermal paste. Short of doing this almost guarantees failure to maintain proper cooling.
Guy Martin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 21
Total : 3,336
