Introduction
If your are having problems turning on the computer your power supply might be at fault. If you need to replace it you will need to remove the side panel, disconnect and dismount the power supply.
Ce dont vous avez besoin
Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
Unscrew the 10.5mm screw on the left of the desktop using your hand.
2 autres ont terminé cette réparation.
