Introduction
Many user have problems with their computer over heating and that is due to a faulty fan or one that is clogged up. If you don't want to replace it and think it only needs to be cleaned you can simply remove it and clean it with computer duster.
Ce dont vous avez besoin
Using a Phillips #1, remove the 8 10.6mm screws.
Also using a Phillips #1, remove the 8.6mm screw.
Using a Phillips #1, remove the two 10.6 mm screws.
Gently pull back on on the cable to unplug it.
7 autres ont terminé cette réparation.
