Aller au contenu principal
HP Envy M6-1205DX Palm Rest Replacement
Ce dont vous avez besoin
  1. HP Envy M6-1205DX Palm Rest Replacement, Battery: étape 1, image 1 de 1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Palm Rest Replacement: étape 2, image 1 de 1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Palm Rest Replacement: étape 3, image 1 de 2 HP Envy M6-1205DX Palm Rest Replacement: étape 3, image 2 de 2
    • Remove the battery.
  4. HP Envy M6-1205DX Palm Rest Replacement, Back Panel: étape 4, image 1 de 1
    • Using a Phillips #1 screwdriver, remove the 8.6 mm screw.
  5. HP Envy M6-1205DX Palm Rest Replacement: étape 5, image 1 de 1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Palm Rest Replacement, Palm Rest: étape 6, image 1 de 1
    • Set the computer facing upwards again.
    • Using the plastic opening tool gently pry the keyboard up.
  7. HP Envy M6-1205DX Palm Rest Replacement: étape 7, image 1 de 3 HP Envy M6-1205DX Palm Rest Replacement: étape 7, image 2 de 3 HP Envy M6-1205DX Palm Rest Replacement: étape 7, image 3 de 3
    • Flip the white tab on the large ribbon cable upward. Gently pull the large ribbon cable out to remove it.
    • Gently pull the small ribbon cable out to remove it.
  8. HP Envy M6-1205DX Palm Rest Replacement: étape 8, image 1 de 3 HP Envy M6-1205DX Palm Rest Replacement: étape 8, image 2 de 3 HP Envy M6-1205DX Palm Rest Replacement: étape 8, image 3 de 3
    • Gently pull the tension cable to remove it.
  9. HP Envy M6-1205DX Palm Rest Replacement: étape 9, image 1 de 1
    • Using a Phillips #1 screwdriver, remove the four 5.6 mm silver screws.
  10. HP Envy M6-1205DX Palm Rest Replacement: étape 10, image 1 de 2 HP Envy M6-1205DX Palm Rest Replacement: étape 10, image 2 de 2
    • Use the plastic opening tool to loosen the palm rest from the frame.
    • Once you pry all of the snaps up lift off the palm rest.
Ryan Hatton
Membre depuis le 11/16/19
634 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team S2-G2, Wilson Fall 2019 Membre de l'équipe IUPUI, Team S2-G2, Wilson Fall 2019
IUPUI-WILSON-F19S2G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 278
