Introduction
We will be showing you how to replace your screen if it is broken or damaged. This is a fairly long process which requires you to be careful.
Ce dont vous avez besoin
Using a Phillips #1, remove the 8 10.6mm screws.
Also using a Phillips #1, remove the 8.6mm screw.
Using a Phillips #1, remove the 3.5mm screw.
Using a Phillips #1, remove the four 10.6mm screws.
There is another screw to remove here, to the left of the big circle under the HDD
Using a Phillips #00, remove the four 2.3 mm black screws.
Lift the screen and frame out of the computer body.
5 autres ont terminé cette réparation.
