Aller au contenu principal
HP Envy M6-1205DX Touchpad Replacement
Ce dont vous avez besoin
  1. HP Envy M6-1205DX Touchpad Replacement, Battery: étape 1, image 1 de 1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Touchpad Replacement: étape 2, image 1 de 1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Touchpad Replacement: étape 3, image 1 de 2 HP Envy M6-1205DX Touchpad Replacement: étape 3, image 2 de 2
    • Remove the battery.
  4. HP Envy M6-1205DX Touchpad Replacement, Touchpad: étape 4, image 1 de 1
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
  5. HP Envy M6-1205DX Touchpad Replacement: étape 5, image 1 de 1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Touchpad Replacement: étape 6, image 1 de 1
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
  7. HP Envy M6-1205DX Touchpad Replacement: étape 7, image 1 de 1
    • Pull the disk drive out to remove it.
  8. HP Envy M6-1205DX Touchpad Replacement: étape 8, image 1 de 2 HP Envy M6-1205DX Touchpad Replacement: étape 8, image 2 de 2
    • Using a Phillips #1, remove the two 2.4mm screws.
  9. HP Envy M6-1205DX Touchpad Replacement: étape 9, image 1 de 2 HP Envy M6-1205DX Touchpad Replacement: étape 9, image 2 de 2
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
  10. HP Envy M6-1205DX Touchpad Replacement: étape 10, image 1 de 2 HP Envy M6-1205DX Touchpad Replacement: étape 10, image 2 de 2
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
  11. HP Envy M6-1205DX Touchpad Replacement: étape 11, image 1 de 3 HP Envy M6-1205DX Touchpad Replacement: étape 11, image 2 de 3 HP Envy M6-1205DX Touchpad Replacement: étape 11, image 3 de 3
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
  12. HP Envy M6-1205DX Touchpad Replacement: étape 12, image 1 de 3 HP Envy M6-1205DX Touchpad Replacement: étape 12, image 2 de 3 HP Envy M6-1205DX Touchpad Replacement: étape 12, image 3 de 3
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
  13. HP Envy M6-1205DX Touchpad Replacement: étape 13, image 1 de 1
    • Using a Phillips #1, remove the four 5.6mm silver screws.
  14. HP Envy M6-1205DX Touchpad Replacement: étape 14, image 1 de 2 HP Envy M6-1205DX Touchpad Replacement: étape 14, image 2 de 2
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
3 autres ont terminé cette réparation.
Alex Wasilewski
Membre depuis le 09/28/16
596 Réputation
5 tutoriels rédigés
Équipe
Un commentaire
I recently replaced my front face plate on my Envy M6, which originally had one in a natural silver finish. I can confirm that the onyx black one works equally well. To think it was a Lithuanian part too. I completed the guide, but mistakenly forgot to reconnect the touchpad ribbon. But that’s my fault.
Eric Shields - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 2,215
