Aller au contenu principal
HP Envy TouchSmart 4-1215dx Display Replacement
Ce dont vous avez besoin
  1. HP Envy TouchSmart 4-1215dx Display Replacement, Display: étape 1, image 1 de 1
    • Remove both 3 mm screws at the bottom of the display using a Phillips #0 screwdriver.
  2. HP Envy TouchSmart 4-1215dx Display Replacement: étape 2, image 1 de 2 HP Envy TouchSmart 4-1215dx Display Replacement: étape 2, image 2 de 2
    • Using an iFixit opening tool, pry the screen from the back panel.
    • Remove the back panel.
  3. HP Envy TouchSmart 4-1215dx Display Replacement: étape 3, image 1 de 1
    • Close the laptop so the front is facing you.
    • Remove the four 3 mm screws from the two brackets at the front using a Phillips #0 screwdriver.
    • Remove the brackets.
  4. HP Envy TouchSmart 4-1215dx Display Replacement: étape 4, image 1 de 3 HP Envy TouchSmart 4-1215dx Display Replacement: étape 4, image 2 de 3 HP Envy TouchSmart 4-1215dx Display Replacement: étape 4, image 3 de 3
    • Remove the 3 mm screws from the back brackets using a Phillips #0 screwdriver.
    • Remove the 1 mm screws with a Phillips #00 screwdriver.
    • Lift up the display until the brackets are sticking straight up.
  5. HP Envy TouchSmart 4-1215dx Display Replacement: étape 5, image 1 de 1
    • Peel off the aluminum tape located at the top of the display.
  6. HP Envy TouchSmart 4-1215dx Display Replacement: étape 6, image 1 de 2 HP Envy TouchSmart 4-1215dx Display Replacement: étape 6, image 2 de 2
    • Disconnect the ribbon cable and peel off the connected tape from the display.
  7. HP Envy TouchSmart 4-1215dx Display Replacement: étape 7, image 1 de 2 HP Envy TouchSmart 4-1215dx Display Replacement: étape 7, image 2 de 2
    • Lift the display up separately from the screen.
    • Peel off the orange tape at the bottom of the display connecting to the laptop.
  8. HP Envy TouchSmart 4-1215dx Display Replacement: étape 8, image 1 de 1
    • Lift up the display.
    • If your display is cracked or shattered, you should tape up the effected parts in order to avoid injury.
Isaac York
Membre depuis le 02/08/22
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 8
Total : 227
