Aller au contenu principal
HP Envy TouchSmart 4-1215dx Motherboard Replacement
Ce dont vous avez besoin
  1. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Back Panel Assembly: étape 1, image 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement, Back Panel Assembly: étape 1, image 2 de 2
    • Remove the thirteen Phillips #0 screws.
  2. HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 2, image 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 2, image 2 de 2
    • Pull the panel up and off to remove from the laptop.
  3. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Battery: étape 3, image 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement, Battery: étape 3, image 2 de 2
    • Unplug the battery from the motherboard.
  4. HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 4, image 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 4, image 2 de 2
    • Remove the three Phillips #0 screws from the battery.
    • Pull the battery out of the laptop.
  5. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Fan: étape 5, image 1 de 1
    • Unplug the fan from the motherboard.
  6. HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 6, image 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 6, image 2 de 2
    • Remove the four Phillips #0 screws holding in the fan.
    • Pull out the fan.
  7. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Wi-Fi Card: étape 7, image 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement, Wi-Fi Card: étape 7, image 2 de 2
    • Remove the single screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Pull the Wi-Fi card out of its slot.
  8. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Heat Sink: étape 8, image 1 de 1
    • Remove four screws from the heat sink using a Phillips #0 screwdriver.
  9. HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 9, image 1 de 1
    • Gently lift the heat sink from the motherboard.
  10. HP Envy TouchSmart 4-1215dx Motherboard Replacement, Motherboard: étape 10, image 1 de 1
    • Remove the remaining from the motherboard with a Phillips #0 screwdriver.
  11. HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 11, image 1 de 3 HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 11, image 2 de 3 HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 11, image 3 de 3
    • Disconnect the remaining cables from the motherboard by gently tugging on the pull tabs or the edges of the connectors that sit in the terminals.
  12. HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 12, image 1 de 2 HP Envy TouchSmart 4-1215dx Motherboard Replacement: étape 12, image 2 de 2
    • Gently lift the motherboard from the housing to remove it from the laptop.
Cassie Hunter
Membre depuis le 02/08/22
97 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 6
Total : 131
