Aller au contenu principal
HP Envy Touchsmart m6-k125dx Motherboard Replacement
Ce dont vous avez besoin
  1. HP Envy Touchsmart m6-k125dx Motherboard Replacement, Back Panel: étape 1, image 1 de 2 HP Envy Touchsmart m6-k125dx Motherboard Replacement, Back Panel: étape 1, image 2 de 2
    • Turn the laptop over so that the bottom is facing up
    • Using the J0 screwdriver, unscrew all 12 M2.5x5.5 screws from the back panel.
  2. HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 2, image 1 de 1
    • Carefully remove the back panel to reveal the inner components.
  3. HP Envy Touchsmart m6-k125dx Motherboard Replacement, Cooling Fan: étape 3, image 1 de 2 HP Envy Touchsmart m6-k125dx Motherboard Replacement, Cooling Fan: étape 3, image 2 de 2
    • Use the J0 screwdriver to remove the two M2.0x3.0 screws holding in the cooling fan
  4. HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 4, image 1 de 3 HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 4, image 2 de 3 HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 4, image 3 de 3
    • Unplug the cord and carefully remove the cooling fan
  5. HP Envy Touchsmart m6-k125dx Motherboard Replacement, Motherboard: étape 5, image 1 de 2 HP Envy Touchsmart m6-k125dx Motherboard Replacement, Motherboard: étape 5, image 2 de 2
    • Use the J1 screwdriver to remove the three M2.5x2.5 screws on the SD card reader.
    • Remove the SD card reader and set it aside.
  6. HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 6, image 1 de 3 HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 6, image 2 de 3 HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Disconnect the six ZIF connectors.
    • Use the tweezers to flip up the plastic retaining flap.
    • Pull the cable out horizontally.
  7. HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 7, image 1 de 2 HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 7, image 2 de 2
    • Disconnect the four remaining connectors.
    • Use a plastic opening tool or spudger if necessary to pry the connector apart.
  8. HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 8, image 1 de 2 HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 8, image 2 de 2
    • Use the J0 screwdriver to remove the two M2.5x2.5 screws on the wireless network card.
    • Slide the card horizontally toward the front of the laptop and out of its socket.
  9. HP Envy Touchsmart m6-k125dx Motherboard Replacement: étape 9, image 1 de 1
    • Use the J1 screwdriver to remove the four M2.5x2.5 screws that secure the motherboard to the case.
    • Pull up on the right side of the motherboard, away from the USB ports, then slide out to the right.
Alan Orr
Membre depuis le 04/06/19
139 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S14-G14, Wilson Spring 2019 Membre de l'équipe IUPUI, Team S14-G14, Wilson Spring 2019
IUPUI-WILSON-S19S14G14
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 17
Total : 625
