Aller au contenu principal
HP Envy Touchsmart m6-k125dx Touch Screen Replacement
Ce dont vous avez besoin
  1. HP Envy Touchsmart m6-k125dx Touch Screen Replacement, Touch Screen: étape 1, image 1 de 1
    • Open the laptop.
    • Remove black tabs at bottom left and right corners and remove the two M2.5x2.5 screws behind the black tabs with the J0 screwdriver.
  2. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: étape 2, image 1 de 2 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: étape 2, image 2 de 2
    • Insert pick between the black plastic screen panel and the silver plastic exterior case on the side of the device.
    • Slide pick around the border of the screen panel while keeping the pick between the mentioned panel and exterior case.
    • Repeat previous two steps until exterior case is removed. Pry with minimal force if necessary.
  3. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: étape 3, image 1 de 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: étape 3, image 2 de 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: étape 3, image 3 de 3
    • Remove the front panel from the rest of the device and set it aside.
    • Remove the ten M2.5x2.5 screws with the J0 screwdriver.
    • Remove the eight M2.0x2.0 screws with the J0 screwdriver.
  4. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: étape 4, image 1 de 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: étape 4, image 2 de 3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: étape 4, image 3 de 3
    • Flip hinges down and away from the rest of the panel.
    • Remove the four M2.5x2.5 screws with the J0 screwdriver.
    • Move 4 pieces of black tape across the bottom of the panel and any other accessory tape.
    • Disconnect the display cable connector that is located at the bottom right of the panel by pulling lightly.
  5. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: étape 5, image 1 de 1
    • Slowly lift the screen away from the touch screen front panel to remove.
2 autres ont terminé cette réparation.
Madison Velchek
Membre depuis le 04/06/19
151 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S14-G14, Wilson Spring 2019 Membre de l'équipe IUPUI, Team S14-G14, Wilson Spring 2019
IUPUI-WILSON-S19S14G14
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 9
Total : 860
