Aller au contenu principal
HP Envy Ultrabook 4-1043cl Cooling Fan Replacement
Ce dont vous avez besoin
  1. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: étape 2, image 1 de 2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: étape 2, image 2 de 2
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: étape 3, image 1 de 1
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: étape 4, image 1 de 2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: étape 4, image 2 de 2
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: étape 5, image 1 de 2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: étape 5, image 2 de 2
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Cooling Fan: étape 6, image 1 de 2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement, Cooling Fan: étape 6, image 2 de 2
    • Remove one 4.2mm screw at the bottom right corner by using the Phillips #00 screwdriver.
  7. HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: étape 7, image 1 de 2 HP Envy Ultrabook 4-1043cl Cooling Fan Replacement: étape 7, image 2 de 2
    • Disconnect the fan from the motherboard and remove it from the device.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 219
