Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Envy Ultrabook 4-1043cl Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 2, image 1 de 2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 2, image 2 de 2
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 3, image 1 de 1
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 4, image 1 de 2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 4, image 2 de 2
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 5, image 1 de 2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 5, image 2 de 2
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: étape 6, image 1 de 3 HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: étape 6, image 2 de 3 HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: étape 6, image 3 de 3
    • The hard drive is in the bottom right corner of the device which is packed by a silver metal shell.
    • Use a Phillips #00 screwdriver to remove the four 4.0 mm screws securing the hard drive to the top cover.
  7. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 7, image 1 de 2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 7, image 2 de 2
  8. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 8, image 1 de 2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: étape 8, image 2 de 2
    • Pull the hard disk drive out of the connector socket and remove it from the device.
Ligne d'arrivée
3 autres ont terminé cette réparation.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 20
Total : 907
