Aller au contenu principal
HP Envy Ultrabook 4-1043cl RAM Replacement
Ce dont vous avez besoin
  1. HP Envy Ultrabook 4-1043cl RAM Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl RAM Replacement: étape 2, image 1 de 2 HP Envy Ultrabook 4-1043cl RAM Replacement: étape 2, image 2 de 2
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl RAM Replacement: étape 3, image 1 de 1
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl RAM Replacement: étape 4, image 1 de 2 HP Envy Ultrabook 4-1043cl RAM Replacement: étape 4, image 2 de 2
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl RAM Replacement: étape 5, image 1 de 2 HP Envy Ultrabook 4-1043cl RAM Replacement: étape 5, image 2 de 2
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: étape 6, image 1 de 3 HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: étape 6, image 2 de 3 HP Envy Ultrabook 4-1043cl RAM Replacement, RAM: étape 6, image 3 de 3
    • The RAM lies in the middle-right side of the device.
    • Use your fingers and push the two clips outwards to release the RAM stick.
  7. HP Envy Ultrabook 4-1043cl RAM Replacement: étape 7, image 1 de 1
    • Remove the RAM from the device.
  8. HP Envy Ultrabook 4-1043cl RAM Replacement: étape 8, image 1 de 3 HP Envy Ultrabook 4-1043cl RAM Replacement: étape 8, image 2 de 3 HP Envy Ultrabook 4-1043cl RAM Replacement: étape 8, image 3 de 3
    • Repeat the previous two steps to remove any other RAM sticks.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 13
Total : 288
