Aller au contenu principal
HP Envy X2-15-C001Dx Speakers Replacement
Ce dont vous avez besoin
  1. HP Envy X2-15-C001Dx Speakers Replacement, Back Panel: étape 1, image 1 de 1
    • Place the laptop face down on a table.
  2. HP Envy X2-15-C001Dx Speakers Replacement: étape 2, image 1 de 2 HP Envy X2-15-C001Dx Speakers Replacement: étape 2, image 2 de 2
    • Lift up the back stand.
  3. HP Envy X2-15-C001Dx Speakers Replacement: étape 3, image 1 de 2 HP Envy X2-15-C001Dx Speakers Replacement: étape 3, image 2 de 2
    • Remove the five screws from the bottom of the back plate using a Phillips #1 screwdriver.
  4. HP Envy X2-15-C001Dx Speakers Replacement: étape 4, image 1 de 1
    • Remove four screws from the back stand hinges using a Phillips #1 screwdriver.
  5. HP Envy X2-15-C001Dx Speakers Replacement: étape 5, image 1 de 2 HP Envy X2-15-C001Dx Speakers Replacement: étape 5, image 2 de 2
    • Remove the hinges and the back stand from the laptop.
  6. HP Envy X2-15-C001Dx Speakers Replacement: étape 6, image 1 de 1
    • Use a spudger to remove the thin panel where the back stand was.
  7. HP Envy X2-15-C001Dx Speakers Replacement: étape 7, image 1 de 1
    • Remove the screws from the back panel using a Phillips #1 screwdriver.
  8. HP Envy X2-15-C001Dx Speakers Replacement: étape 8, image 1 de 2 HP Envy X2-15-C001Dx Speakers Replacement: étape 8, image 2 de 2
    • Remove two side screws using a Phillips #1 screwdriver.
  9. HP Envy X2-15-C001Dx Speakers Replacement: étape 9, image 1 de 2 HP Envy X2-15-C001Dx Speakers Replacement: étape 9, image 2 de 2
    • Pry apart the base from the screen by going around the entire perimeter with an opening tool.
  10. HP Envy X2-15-C001Dx Speakers Replacement: étape 10, image 1 de 2 HP Envy X2-15-C001Dx Speakers Replacement: étape 10, image 2 de 2
    • Remove the back panel from the laptop.
  11. HP Envy X2-15-C001Dx Speakers Replacement, Speakers: étape 11, image 1 de 1
    • Flip up the black retaining flap securing the speaker's ribbon cable.
    • Slide the ribbon cable out of the connector.
  12. HP Envy X2-15-C001Dx Speakers Replacement: étape 12, image 1 de 1
    • Disconnect the black speaker wire from the motherboard.
  13. HP Envy X2-15-C001Dx Speakers Replacement: étape 13, image 1 de 1
    • Lift the left speaker up and away from the laptop.
  14. HP Envy X2-15-C001Dx Speakers Replacement: étape 14, image 1 de 1
    • Unplug the black right speaker wire from its connection on the motherboard.
    • Lift the right speaker out of the laptop to remove it.
Dylan Hathaway
Membre depuis le 10/25/21
683 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 2-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 105
