Aller au contenu principal
HP Envy dv7t-7200 Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Envy dv7t-7200 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Hard Drive Replacement: étape 2, image 1 de 3 HP Envy dv7t-7200 Hard Drive Replacement: étape 2, image 2 de 3 HP Envy dv7t-7200 Hard Drive Replacement: étape 2, image 3 de 3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Hard Drive Replacement: étape 3, image 1 de 1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Hard Drive Replacement, Service Cover: étape 4, image 1 de 1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Hard Drive Replacement: étape 5, image 1 de 2 HP Envy dv7t-7200 Hard Drive Replacement: étape 5, image 2 de 2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 Hard Drive Replacement, Hard Drive: étape 6, image 1 de 1
    • Remove the 2 Phillips PM2.5×5.5 top screws from brackets on both hard drives.
  7. HP Envy dv7t-7200 Hard Drive Replacement: étape 7, image 1 de 1
    • Remove the primary drive first located on the right hand side.
    • Use the black tab to lift the drive up and out.
  8. HP Envy dv7t-7200 Hard Drive Replacement: étape 8, image 1 de 1
    • Remove the 2 Phillips PM2.5×5.5 screws on each side of the drive bracket.
  9. HP Envy dv7t-7200 Hard Drive Replacement: étape 9, image 1 de 1
    • Remove the hard drive connector cable.
    • This cable can be difficult to remove. Try to pull this cable firmly and carefully.
  10. HP Envy dv7t-7200 Hard Drive Replacement: étape 10, image 1 de 1
    • Repeat steps 6-9 for the secondary hard drive.
To reassemble your device, follow these instructions in the reverse order.
Krystal
Membre depuis le 10/16/17
882 Réputation
8 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G3, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 349
