Aller au contenu principal
HP Envy dv7t-7200 Keyboard Assembly Replacement
Ce dont vous avez besoin
  1. HP Envy dv7t-7200 Keyboard Assembly Replacement, Battery: étape 1, image 1 de 1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 2, image 1 de 3 HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 2, image 2 de 3 HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 2, image 3 de 3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 3, image 1 de 1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Keyboard Assembly Replacement, Service Cover: étape 4, image 1 de 1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 5, image 1 de 2 HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 5, image 2 de 2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 Keyboard Assembly Replacement, Optical Disc Drive: étape 6, image 1 de 1
    • Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
  7. HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 7, image 1 de 2 HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 7, image 2 de 2
    • Press the tab with a metal spudger that is located next to the screw to release the optical drive.
  8. HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 8, image 1 de 2 HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 8, image 2 de 2
    • Slide the disk drive out of the laptop.
  9. HP Envy dv7t-7200 Keyboard Assembly Replacement, Keyboard Assembly: étape 9, image 1 de 1
    • Place the laptop on it’s top
    • Remove the two screws that secure the keyboard to the laptop.
  10. HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 10, image 1 de 1
    • Stand the laptop on it’s left side with it’s top open.
    • Locate the circular opening in the optical drive slot.
    • Using a plastic opener, press on the keyboard through this opening until it lifts the keyboard away.
  11. HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 11, image 1 de 1
    • Place the laptop on it’s back with the front facing you.
    • Using a plastic opener, lift the back of the keyboard towards you releasing it from the lip that holds it.
    • You will hear slight popping noises as the keyboard separates.
  12. HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 12, image 1 de 1
    • The keyboard is still attached by two ribbon cables. Lift the keyboard slowly during this step.
    • Lift keyboard up and place upside down on laptop.
  13. HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 13, image 1 de 1
    • Release the connectors that attach the keyboard to the laptop.
  14. HP Envy dv7t-7200 Keyboard Assembly Replacement: étape 14, image 1 de 1
    • Remove the keyboard.
2 autres ont terminé cette réparation.
Krystal
Membre depuis le 10/16/17
882 Réputation
8 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G3, Liner Fall 2017 Membre de l'équipe UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 374
