Aller au contenu principal
HP Envy m6-1105dx WLAN Card Replacement
Ce dont vous avez besoin
  1. HP Envy m6-1105dx WLAN Card Replacement, Battery: étape 1, image 1 de 1
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx WLAN Card Replacement: étape 2, image 1 de 1
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx WLAN Card Replacement, WLAN Card: étape 3, image 1 de 1
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx WLAN Card Replacement: étape 4, image 1 de 2 HP Envy m6-1105dx WLAN Card Replacement: étape 4, image 2 de 2
    • Use a JIS #0 screwdriver to unscrew the small cover where the WLAN card is.
    • The screw does not come out all the way so unscrew it as far as you can then try to life the cover.
  5. HP Envy m6-1105dx WLAN Card Replacement: étape 5, image 1 de 3 HP Envy m6-1105dx WLAN Card Replacement: étape 5, image 2 de 3 HP Envy m6-1105dx WLAN Card Replacement: étape 5, image 3 de 3
    • Use a plastic opening tool to gently disconnect the WLAN antenna cables.
  6. HP Envy m6-1105dx WLAN Card Replacement: étape 6, image 1 de 2 HP Envy m6-1105dx WLAN Card Replacement: étape 6, image 2 de 2
    • Remove the two PM2.0×3.0 screws that secure the WLAN module to the base using the JIS #0 screwdriver.
    • Using two fingers, grab the sides of the WLAN card and slowly pull it out.
Ian Mwalago
Membre depuis le 10/14/18
303 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G5, Valliere Fall 2018 Membre de l'équipe UMass Dartmouth, Team S1-G5, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G5
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 602
