Aller au contenu principal
HP Envy m6-k022dx CPU Fan Replacement
Ce dont vous avez besoin
  1. HP Envy m6-k022dx CPU Fan Replacement, Lower Case: étape 1, image 1 de 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx CPU Fan Replacement: étape 2, image 1 de 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx CPU Fan Replacement: étape 3, image 1 de 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx CPU Fan Replacement: étape 4, image 1 de 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx CPU Fan Replacement, CPU Fan: étape 5, image 1 de 1
    • The fan is located here. You will need to remove three screws in order to lift the fan out from the motherboard.
    • You will need a Phillips 00 size screwdriver to remove the screws.
  6. HP Envy m6-k022dx CPU Fan Replacement: étape 6, image 1 de 1
    • Use your screwdriver to remove the three screws connecting the fan to the motherboard.
  7. HP Envy m6-k022dx CPU Fan Replacement: étape 7, image 1 de 1
    • Grab the fan with your hand, and lift up and away from the motherboard.
  8. HP Envy m6-k022dx CPU Fan Replacement: étape 8, image 1 de 1
    • Grab the fan power connector by the wires and pull directly away from port until the cable is disconnected.
Jibreel Campbell
Membre depuis le 03/02/17
276 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S13-G6, Cagle Spring 2017 Membre de l'équipe USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 792
