Aller au contenu principal
HP Envy m6-k022dx RAM Replacement
Ce dont vous avez besoin
  1. HP Envy m6-k022dx RAM Replacement, Lower Case: étape 1, image 1 de 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx RAM Replacement: étape 2, image 1 de 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx RAM Replacement: étape 3, image 1 de 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx RAM Replacement: étape 4, image 1 de 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx RAM Replacement, RAM: étape 5, image 1 de 1
    • The RAM sticks are located in the right upper corner of the laptop of the laptop.
  6. HP Envy m6-k022dx RAM Replacement: étape 6, image 1 de 1
    • There are two clips holding each RAM stick in place; one on each side of each stick.
    • Gently pull each clips outwards, away from the RAM sticks. They will easily unclip from the RAM.
  7. HP Envy m6-k022dx RAM Replacement: étape 7, image 1 de 1
    • Grab the top of the RAM stick and pull directly up, towards the outer edge of the laptop.
    • The RAM sticks will slide out from their slots relatively easily. They are now ready to be replaced.
3 autres ont terminé cette réparation.
Anthony Stubbs
Membre depuis le 04/06/17
182 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S13-G6, Cagle Spring 2017 Membre de l'équipe USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,110
