Aller au contenu principal
HP Envy m6-k022dx Speaker Replacement
Ce dont vous avez besoin
  1. HP Envy m6-k022dx Speaker Replacement, Lower Case: étape 1, image 1 de 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx Speaker Replacement: étape 2, image 1 de 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx Speaker Replacement: étape 3, image 1 de 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx Speaker Replacement: étape 4, image 1 de 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx Speaker Replacement, Speaker: étape 5, image 1 de 1
    • Remove the two screws holding the speaker in place.
    • There are two red rubber grommets which stay situated in the screw guide holes; be sure not to lose these.
  6. HP Envy m6-k022dx Speaker Replacement: étape 6, image 1 de 1
    • Once the screws have been removed, gently lift the speaker straight up, but just enough to dislodge it.
    • There is a cable connecting the speakers to the sound board. Be sure to not tug on this connection when lifting the speaker.
  7. HP Envy m6-k022dx Speaker Replacement: étape 7, image 1 de 1
    • Once the speaker is dislodged, gently pull the connecting cable from the sound card.
    • The speaker is now fully removed and ready to be replaced.
Kareem Rigaud
Membre depuis le 03/02/17
403 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S13-G6, Cagle Spring 2017 Membre de l'équipe USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 16
Total : 679
