Introduction
This guide demonstrates how to properly remove the CPU of a HP Envy m6-n010dx.
Find the battery removal slider.
  • Find the battery removal slider.
  • Slide it across while simultaneously popping out and removing the device's battery.
Ajouter un commentaire
Remove the five marked screws found under the battery using a philips head screwdriver.
  • Remove the five marked screws found under the battery using a philips head screwdriver.
  • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
  • Gently pry off the cover to release the cable.
  • Slowly lift the hard drive out and away from the device.
  • Remove the 6 highlighted 1.5 mm screws using a #00 philips head screwdriver.
  • Pry off the lower two grip pads highlighted in orange.
    • Remove the two additional 1.5mm screws underneath the lower grip pads using a #00 philips head screwdriver.
    • You may need to use more force than feels necessary.
  • Remove the large back panel to reveal the inner workings.
    • The CPU can be found underneath the heatsink, highlighted in yellow.
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  • Loosen the four 1.5 mm screws on the heat sink using a #00 philips head screwdriver.
  • Remove the tape holding the heatsink to the fan.
  • Remove the heatsink.
  • When putting everything back together, use a new strip of electrical tape to make sure the parts are properly secured.
  • Find the uncovered CPU highlighted in red.
  • Turn the fastener, highlighted in orange, 180 degrees counterclockwise using a flat headed screwdriver to loosen the CPU.
  • Gently lift up and remove the CPU
  • Only lift the CPU by the sides, making sure not to touch the bottom, otherwise you may damage your CPU.
  • Don't forget to apply a few drops of thermal paste when putting in a new CPU.
To reassemble your device, follow these instructions in reverse order. Be sure to apply new thermal paste if you are using a new CPU.
2 autre(s) ont terminé cette réparation.
Sam Klink
Membre depuis le 08/02/2018
169 Réputation
1 tutoriel rédigé
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 84
