Aller au contenu principal
HP Envy m6-n010dx CPU Replacement
Ce dont vous avez besoin
  1. HP Envy m6-n010dx CPU Replacement, Battery: étape 1, image 1 de 3 HP Envy m6-n010dx CPU Replacement, Battery: étape 1, image 2 de 3 HP Envy m6-n010dx CPU Replacement, Battery: étape 1, image 3 de 3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx CPU Replacement, Hard Drive: étape 2, image 1 de 1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx CPU Replacement: étape 3, image 1 de 2 HP Envy m6-n010dx CPU Replacement: étape 3, image 2 de 2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx CPU Replacement: étape 4, image 1 de 3 HP Envy m6-n010dx CPU Replacement: étape 4, image 2 de 3 HP Envy m6-n010dx CPU Replacement: étape 4, image 3 de 3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx CPU Replacement, CPU: étape 5, image 1 de 3 HP Envy m6-n010dx CPU Replacement, CPU: étape 5, image 2 de 3 HP Envy m6-n010dx CPU Replacement, CPU: étape 5, image 3 de 3
    • Remove the 6 highlighted 1.5 mm screws using a #00 philips head screwdriver.
    • Pry off the lower two grip pads highlighted in orange.
    • Remove the two additional 1.5mm screws underneath the lower grip pads using a #00 philips head screwdriver.
    • You may need to use more force than feels necessary.
    • Remove the large back panel to reveal the inner workings.
    • The CPU can be found underneath the heatsink, highlighted in yellow.
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx CPU Replacement: étape 6, image 1 de 3 HP Envy m6-n010dx CPU Replacement: étape 6, image 2 de 3 HP Envy m6-n010dx CPU Replacement: étape 6, image 3 de 3
    • Loosen the four 1.5 mm screws on the heat sink using a #00 philips head screwdriver.
    • Remove the tape holding the heatsink to the fan.
    • Remove the heatsink.
    • When putting everything back together, use a new strip of electrical tape to make sure the parts are properly secured.
  7. HP Envy m6-n010dx CPU Replacement: étape 7, image 1 de 3 HP Envy m6-n010dx CPU Replacement: étape 7, image 2 de 3 HP Envy m6-n010dx CPU Replacement: étape 7, image 3 de 3
    • Find the uncovered CPU highlighted in red.
    • Turn the fastener, highlighted in orange, 180 degrees counterclockwise using a flat headed screwdriver to loosen the CPU.
  8. HP Envy m6-n010dx CPU Replacement: étape 8, image 1 de 3 HP Envy m6-n010dx CPU Replacement: étape 8, image 2 de 3 HP Envy m6-n010dx CPU Replacement: étape 8, image 3 de 3
    • Gently lift up and remove the CPU
    • Only lift the CPU by the sides, making sure not to touch the bottom, otherwise you may damage your CPU.
    • Don't forget to apply a few drops of thermal paste when putting in a new CPU.
To reassemble your device, follow these instructions in reverse order. Be sure to apply new thermal paste if you are using a new CPU.
3 autres ont terminé cette réparation.
Sam Klink
Membre depuis le 02/08/18
196 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 927
