Introduction
This guide demonstrates how to properly remove the fan of a HP Envy m6-n010dx. You will be using a Phillips 00 screwdriver throughout this guide.
Find the battery removal slider.
  • Find the battery removal slider.
  • Slide it across while simultaneously popping out and removing the device's battery.
Ajouter un commentaire
Remove the five marked screws found under the battery using a philips head screwdriver.
  • Remove the five marked screws found under the battery using a philips head screwdriver.
  • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
  • Gently pry off the cover to release the cable.
  • Slowly lift the hard drive out and away from the device.
  • Remove the screws highlighted in red
  • Pry off with prying tool the lower two grip pads highlighted in orange
    • You may need to use more force than feels necessary
  • Remove the two additional screws underneath the lower grip pads
  • Remove the large back panel to reveal the inner workings
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  • Locate fan
  • Gently remove tape that hold the heatsink and fan together
  • When reassembling , make sure to use new electrical tape so it will stick.
  • Loosen the four screws on the heat sink indicated in picture
  • Remove the heatsink
  • Gently disconnect the wire connecting the fan to the motherboard
  • Remove screws indicated in photo.
  • Remove fan
2 autre(s) ont terminé cette réparation.
Sandra Ramirez
Membre depuis le 08/02/2018
151 Réputation
1 tutoriel rédigé
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 26
Total : 114
