Aller au contenu principal
HP Envy m6-n010dx RAM Replacement
Ce dont vous avez besoin
  1. HP Envy m6-n010dx RAM Replacement, Battery: étape 1, image 1 de 3 HP Envy m6-n010dx RAM Replacement, Battery: étape 1, image 2 de 3 HP Envy m6-n010dx RAM Replacement, Battery: étape 1, image 3 de 3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx RAM Replacement, Hard Drive: étape 2, image 1 de 1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx RAM Replacement: étape 3, image 1 de 2 HP Envy m6-n010dx RAM Replacement: étape 3, image 2 de 2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx RAM Replacement: étape 4, image 1 de 3 HP Envy m6-n010dx RAM Replacement: étape 4, image 2 de 3 HP Envy m6-n010dx RAM Replacement: étape 4, image 3 de 3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx RAM Replacement, RAM: étape 5, image 1 de 3 HP Envy m6-n010dx RAM Replacement, RAM: étape 5, image 2 de 3 HP Envy m6-n010dx RAM Replacement, RAM: étape 5, image 3 de 3
    • Remove the highlighted screws
    • Pry off the lower two grip pads
    • You may need to use more force than feels necessary
    • Remove the two additional screws underneath the lower grip pads
    • Remove the large back panel to reveal the inner workings
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx RAM Replacement: étape 6, image 1 de 3 HP Envy m6-n010dx RAM Replacement: étape 6, image 2 de 3 HP Envy m6-n010dx RAM Replacement: étape 6, image 3 de 3
    • Pull back the black rectangular cover to reveal the RAM
    • Unclip the metal restraints on the side to pop out the RAM
    • Repeat the previous step for the second RAM below
Johnathan Morales
Membre depuis le 02/08/18
393 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 255
