Aller au contenu principal
HP Envy x2 13-j002dx Battery Replacement
Ce dont vous avez besoin
  1. HP Envy x2 13-j002dx Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Battery Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Battery Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Battery Replacement: étape 4, image 1 de 2 HP Envy x2 13-j002dx Battery Replacement: étape 4, image 2 de 2
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Battery Replacement: étape 5, image 1 de 1
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Battery Replacement: étape 6, image 1 de 1
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Battery Replacement: étape 7, image 1 de 2 HP Envy x2 13-j002dx Battery Replacement: étape 7, image 2 de 2
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Battery Replacement: étape 8, image 1 de 1
    • Carefully lift up and remove the battery.
5 autres ont terminé cette réparation.
Aaron Page
Membre depuis le 01/17/19
418 Réputation
1 tutoriel rédigé
Un commentaire
For step 2, when I was taking the screws out, they were held in by the magnets that were on either side of them making it difficult to remove. I ended up having to use another magnet to get them out.
Reed Jochimsen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 24
Total : 1,912
